Temp Sensor/Sender
Old Apr 9, 2011 | 08:07 PM
totsie14's Avatar
totsie14
Default Temp Sensor/Sender
Okay, I'm literally at my wits end with this crap, so I need your guys' help.
My temp gauge has never worked since the day I bought it and I've been loosing antifreeze like crazy through the goose neck of my truck, so I replaced the gasket and bought a new clamp. Anyways - I'm having a hard time figuring something out - my gauge doesn't work, so I go to Napa, ask the lady for a temperature sensor because my gauge never worked. She grabbed me a sensor that was $25, and I left.
Now I'm looking at the sensor behind the alternator with one prong, and I have a sensor from Napa with 2 prongs. Where's the other sensor?! Which one do I need to replace? Did I get the wrong sensor, and need to go back for a temperature sender??
Old Apr 9, 2011 | 08:18 PM
siggie30's Avatar
siggie30
The single wire type is a direct wire to the guage (or bulkhead connector). The two prong type splits and one wire goes through the computer (orange/white?), and the other goes to the gauge.
Old Apr 9, 2011 | 09:02 PM
Hahns5.2's Avatar
Hahns5.2
Originally Posted by siggie30
Thw single wire type is a direct wire to the guage (or bulkhead connector). The two prong type splits and one wire goes through the computer (orange/white?), and the other goes to the gauge.
Negative.
The 2 wire sensor is for the PCM only and the single wire sensor is for the gauge only.
Old Apr 9, 2011 | 09:23 PM
siggie30's Avatar
siggie30
Originally Posted by Hahns5.2
Negative.
Ummm, that's what I said (with exception).
EDIT: I reviewed my schematics, and I am going to go with my original statement.
FSM for the 95' states in section 8W-40-8 that a violet and yellow wire goes directly to the guage. The pre 91' has 2 wires one of which goes to the ECM and the other goes to the gauge. I will say that I do not have the 96' FSM and am figuring on the 95' to be an accurate representation.
To the OP: Yes, she gave you the wrong sensor, because she is a saleswoman and not a mechanic.
Old Apr 9, 2011 | 09:48 PM
Hahns5.2's Avatar
Hahns5.2
Your original statement is wrong for a magnum, the PCM sensor does not interact with the gauge at all, if it did, there wouldn't be 2 sensors. And yes the violet and yellow wire is for the single wire sensor that goes to the gauge.
Old Apr 9, 2011 | 10:17 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The sensor for the gauge is actually called a sender unit. Since you asked for a sensor she gave you a sensor which is for the computer. You asked for the wrong part. Ask for a coolant sender unit. Look at the diagram.
Old Apr 9, 2011 | 10:38 PM
totsie14's Avatar
totsie14
^ That gave me a good chuckle my good sir!
Anyways, thanks everyone for the help - I actually managed to get ahold of someone at Autozone after I realized that it was in fact the 'sender' that I needed, and not the 'sensor'. They were still open and I got it for like $10, compared to the 25 I spent on the wrong one... luckily, it's returnable.
And special thanks to Crazy4x4RT for the diagram - it was of great help, sir!
I dunno what I would do without you fellow Dakota fanatic's...
Old Apr 9, 2011 | 11:16 PM
shadowthedakota's Avatar
shadowthedakota
i know what i would do...i'd cry at a broken down vehicle in my driveway...lol
Old Apr 10, 2011 | 12:47 AM
totsie14's Avatar
totsie14
I hear ya man, I hear ya!
