1992Dakota Steering Shaft Question
How does this come out? Is it presses in or an allen bolt (that's what is looks like). Also if it's pressed in, which side should I bang on to get it out (see pics). Thanks in advance.
It is a press in pin. You would have to press out the pin from the end with the hole. Using an air hammer would be best. It is almost like a rivet where the other end expands.
But if your trying to remove the steering shaft that is not where you want to remove it. You would remove the bolt/pin from the slip yoke that connects to the steering gear box. Just below the U-Joint in you pic. Again use an air hammer to knock out the pin, this one is just a compression pin so it is meant to be removed if necessary. Trust me an air hammer will knock it out quick.
