where can u get a 3 inch body lift
Old Apr 23, 2011 | 08:17 PM
walkerman2188's Avatar
walkerman2188
Default where can u get a 3 inch body lift
where in the world can you get a 3 inch body lift 4 a 89 dakota 4x4 ive seen a couple of dakotas around the same year have them
Old Apr 23, 2011 | 08:56 PM
logancounterman's Avatar
logancounterman
nowhere they don't make them no more just the 2 inch body lifts but you could stack hockey pocks on top of each other and then drill a hole in them and make your own...
Old Apr 23, 2011 | 09:34 PM
Georges96's Avatar
Georges96
If you use your truck for any kind of off road stuff, you run the risk of them splitting. My friends did in the back of his Bronco. They do have their limits
Old Apr 26, 2011 | 09:57 AM
Nickdakotafling's Avatar
Nickdakotafling
I am using a 3 inch body lift for a ford ranger im just buying the extra parts that i need i.e. extra spacers bolts and nuts. and i have to weld together my shifter rod though because of the gap that itll cause
Old Apr 26, 2011 | 06:46 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes correct 3in is no longer made. 2in is the only available one. You can pieces it together. Just buy the total amount of 3in blocks and longer bolts.
