Rear Brakes Won't Adjust
So, I replaced my whole braking system.
Bled the brakes. Ok.
But the rear brakes just don't auto adjust.
The adjustment wheel is greased (the internal threads), and moves great when spinning by hand.
The adjustment lever "clicks" against the teeth of the star-wheel when spinning by hand to reduce shoe-to-drum clearance. (And the star-wheel will not spin backwards to increase shoe-to-drum clearance, without of course, moving the lever out of the way)
But with the drum actually installed, and doing the drive forward and coming to a complete stop, drive backwards and coming to a complete stop and redoing this many times (as told in the service manual), it just won't auto adjust.
Looking at it with the drum off and having a friend press on the brakes, it appears that the adjustment lever actually jumps off the teeth of the star-wheel (without moving it), and when releasing the brakes, comes back to normal (again, without moving the star-wheel)
I've tried slightly bending a lever, but this doesn't seem to have done anything.
I can still stop but there is a light feel in the brakes, you kind of have to press down farther than normal, and it doesn't feel very firm. Like I said, I've bleed the system.
Any pointers?
BTW, got an alignment done on her the other day. Shes on the road again! I can start using her, just have to fix the little things, one at a time!
Any pointers?
In another thread lots of us said that the self adjusting systems never works on rear brakes. I know every now and then when I pull the rear tire I check the brakes and they are not properly adjusted. I think the system is inadequate.
Just tighten it up to get a good lose tight fit then your good to go.
