96 3.9 stalla after 10 minutes idling restarts 1 hour later
Old May 2, 2011 | 11:47 AM
rochman's Avatar
rochman
Angry 96 3.9 stalla after 10 minutes idling restarts 1 hour later
I have a 96 3.9 that starts fine, but stalls 10-15 minutes later. It will start again about one hour later, for another 10-15 minutes, then the same thing. I have replaced the crank pos. sensor and pick up coil in dist. with no luck. Sometimes gives a 11 code, no dist. input signal. It is not the cat. conv. either. Very frustrating, any suggestions would be appreciated. Thanks in advance. Ready to sell if any takers, Cocoa,Fl.
Old May 2, 2011 | 11:50 AM
1992DakotaDead's Avatar
1992DakotaDead
You and I should be working together.
Read: She's Dead Again
Old May 2, 2011 | 02:41 PM
9652dakota's Avatar
9652dakota
see if you loose fuel or spark. you need to check that the injectors are firing and there is fuel pressure.
don't forget to check for spark.
finding out what it's loosing will cut down what you test by more than half.
