42 or 46 rh
Old May 7, 2011 | 04:55 PM
jonl326's Avatar
jonl326
Default 42 or 46 rh
How can you tell between the two visually
Old May 7, 2011 | 04:59 PM
Crazy4x4RT's Avatar
Crazy4x4RT
There is no way to know with out looking at the part numbers that are stamped onto it. The first thing to look at is what truck/engine it came off of. V8 is 46rh. V6 42rh some Ram V6's had a 46rh so part number would be best.
Old May 7, 2011 | 05:23 PM
jonl326's Avatar
jonl326
ok where on the trany would I find the numbers see I bought this truck used and there has been nothing in it that has been for a 95 everything has been changed for some other year most of it is a 92 and I am hoping that the trany might be a 46 rh probably not with my luck would love to put a nv 4500 in it
Old May 7, 2011 | 07:07 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It is on the driver side, right above the oil pan. The service manual in the FAQ has a diagram.
Old May 7, 2011 | 07:36 PM
siggie30's Avatar
siggie30
Um, an obvious difference is the oil pan and 3rd high housing. The 46rh has a "wing" whereas the 42rh does not. The reason why I mention the 3rd high extention is that the 46rh has the exact same shape of oil pan as the older 727. A common swap to older mopar enthusiasts is to swap the pan from a newer model vehicle for extra oil.
