HELP! Turn the key and no power to ANYTHING
Old May 8, 2011 | 03:37 PM
tjwood's Avatar
tjwood
Default HELP! Turn the key and no power to ANYTHING
Today I was fixing my exhaust and after i was finished went to go start it nothing at all, no power to the lights interior and exterior tested the battery and its getting voltage still no start though. Any ideas?
Old May 8, 2011 | 06:07 PM
Crazy4x4RT's Avatar
Crazy4x4RT
If nothing works first check the battery connections, make sure they are clean and nice and tight. Then check your wires and grounds make sure they are clean and tight.
Old May 8, 2011 | 09:16 PM
tjwood's Avatar
tjwood
all wires and connections are tight cleaned off including the battery and starter solenoid wires still nothing..
Old May 8, 2011 | 09:56 PM
siggie30's Avatar
siggie30
Assumably your at infinite resistance, but..... were you welding on your exhaust with the battery connected?
Old May 8, 2011 | 10:21 PM
issakar's Avatar
issakar
ooooooo :-/ good point.......
