Leaf Spring Purchase
Old May 9, 2011 | 01:36 PM
InnerCityHillBilly's Avatar
InnerCityHillBilly
Default Leaf Spring Purchase
other than a Junkyard, where would be some good places to look for leaf springs. Meaning websites and stuff like that. Looked online but im not wanting to get ripped of cause i dont know anyone that buys parts off line
Old May 9, 2011 | 01:58 PM
Crazy4x4RT's Avatar
Crazy4x4RT
New or used? Tons of sites Google it. Here is one I got book marked. http://www.generalspringkc.com/index.php
Old May 9, 2011 | 02:53 PM
InnerCityHillBilly
do you know of any sites that offered used ones, could adding a block to one side be safe or work? trying to level out the back
Old May 9, 2011 | 05:04 PM
Crazy4x4RT's Avatar
Crazy4x4RT
www.carparts.com or www.criagslist.org or Your local junkyard for used.
If it is 1in or less the block may be okay. But I don't recommend blocks.
An Add A Leaf kit will do. Do both sides if it is not even do only the sagging side.
www.summitracing.com $50 or so.
Old May 9, 2011 | 06:05 PM
InnerCityHillBilly
is the leaf size 2.5 in width? found some on summit for cheap
Old May 9, 2011 | 10:59 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it is. It could also be slightly wider or narrower.
Old May 10, 2011 | 11:23 AM
InnerCityHillBilly
So if i buy the add a leaf i should get the clsest width possible
Old May 10, 2011 | 02:06 PM
InnerCityHillBilly
when i install the add a leaf where is the best place to put it, would the bottom be best, and would it be safe to add 2 and if so where would the second one go?
Old May 10, 2011 | 11:06 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes get as close to the width as possible.
Most likely install it on the bottom or if you have shorter leafs than the AAL then put it over the shorter ones and below the larger ones. Keep them in order short to long.
Yes you can do 2. It may make it overly stiff. 1 kit includes 2 leafs, 1 leaf per side. Usually they come with new center pins. If not they are cheep, you will need New longer ones.
Old May 12, 2011 | 11:09 PM
bill55az's Avatar
bill55az
ESPO Springs and things....good prices...
