Axil change out???
O.K. guys, gave upAlldata so I have a question. Is the rear axil held in only by the bolts at the hub or are there C clips at the Differential to unlock the axil? I sure hope its only 4 bolts that way its a simple fix.
Our factory axles are semi-floating axles, so there are clips holding the axle shafts to the differential.
There are 2 types of rear axles... semi-floating and full-floating. Semi-floating axles have clips at the differential to keep the axle shafts in place and the axle shaft has to hold the weight of the truck. Full-floating axles have spindles/hubs at the wheel end of the axle and use bolts to hold the axle shaft to the hubs. On full-floating axles the weight of the truck is held by the spindle/hub assembly and the axle shaft is only responsible for handling torque. Full-floating axles are only found in heavy-duty full size pickups and larger trucks. Semi-floating axles are found in light duty half tons and lighter trucks.
OUR semi-floaters do use C-clips, though.
