Transmission Delays
Old May 23, 2011 | 06:01 PM
  #21
1992DakotaDead's Avatar
1992DakotaDead
Bump for any part numbers.
Thanks.
Old May 24, 2011 | 10:39 AM
  #22
misfitdakota_95's Avatar
misfitdakota_95
sorry for taking a few days to get back to you, but I do have the part numbers. The transmission cooler line/drainback valve assembly part number is 4883804AC. Again it is the transmission pressure cooler line/drainback valve assembly. The quick-connect fitting/nut part number is 6033879. These are all good part numbers I checked with 3 other dealers these parts are NOT discontinued and you can order it, takes about 3 to 5 days to receive it.
Old May 25, 2011 | 02:50 PM
  #23
1992DakotaDead
Thank You!
So few seem to go the distance and/or able to give that detailed of information. (In life, not specifically this forum, which has been very helpful.)
Thanks again.
