Engine Numbers? 92 Dakota
Old May 13, 2011 | 11:04 AM
1992DakotaDead's Avatar
1992DakotaDead
Default Engine Numbers? 92 Dakota
Wondering where the engine numbers would/should be stamped on a 1992 Dakota V6.
Used truck. Trying to identify if it's the original engine or not.
Thanks for any help.
Old May 13, 2011 | 01:43 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It should be near the bell housing. Do a google search tons of sites with full details on the brake down of the numbers.
Old May 13, 2011 | 03:14 PM
1992DakotaDead
I've Googled:
Dakota Engine Numbers
92 Dodge Engine Numbers
92 Dakota Engine Numbers
Dakota Block Numbers
Dakota V6 Engine & Block Numbers
Dakota Serial Numbers
Etc. Etc. Etc.
Everything that pops up is about the VIN or the sizes & changes through the generations.
I couldn't find anything about the actual location & decoding. I'll keep looking.
Thanks.
Old May 13, 2011 | 05:14 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Try Dodge Engine Casting number
Or Dodge Magnum Engine Casting number
Also the FAQ has the service manual that has the location with pictures.
Old May 13, 2011 | 07:57 PM
1992DakotaDead
Haven't found it. Looked through the 95 FSM. The FAQ's. Multiple Google searches.
As of this post, over 50 views and no-one has said for example:
"Look on the passenger side under the front spark plug. The numbers/letters will be A-B-C-D-1-2-3-4 & they mean XYZ......"
Must be a mystery or my searching sucks.
Maybe I should ask the question in a different way.
If a person were to buy a 3.9 engine, new (possible?), or it comes cleaned & rebuilt in a crate, where would numbers be on that engine related to it's details and build date?
Thanks.
Old May 14, 2011 | 02:10 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Here is copy of page 49, first page of the V6 Engine page.
Here is a link with more info. http://dodgeram.org/tech/gas/specs/id.html
Old May 14, 2011 | 06:36 PM
1992DakotaDead
Thanks. I know you get tired of the repetitive questions over time from different people & would just wish they would read all of the FAQ & use searches.
I try, but sometimes suck at it.
Thanks again.
