99 Dakota Parts
Old May 14, 2011 | 03:49 PM
dobaroy's Avatar
dobaroy
Default 99 Dakota Parts
Friend is parting out a '99 Dakota 5.2 Magnum. We are buying the posi rear end from him, wondering if there would be anything else in this truck that would fit our 1992 5.2 Magnum. Trucks are both auto and both 2 wheel drive. I know the transmissions are different, any suggestions would be welcome.
Old May 14, 2011 | 09:36 PM
siggie30's Avatar
siggie30
Well, the engine is 7 years newer, so should be the parts. Not sure what is wrong with yours that you would consider needing additional parts.
Old May 15, 2011 | 07:53 AM
dobaroy's Avatar
dobaroy
Was just thinking, maybe keep the sensors and stuff like that around in case we need them later. Would the motors interchange from '99 to '92?
Old May 15, 2011 | 11:46 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes the motor would work. You would need to use your intake and electronics.
Old May 16, 2011 | 08:14 AM
dobaroy's Avatar
dobaroy
Thanks for the replies. Would there be much difference in the hp between the '92 and '99, both stock motors?
Old May 16, 2011 | 09:06 PM
siggie30's Avatar
siggie30
If memory serves the 92' has better exhaust manifolds worth about 10 torque. The cam in 99' is a .432 w/1.6 and a duration of 264/250 intake/exhaust. The 92 has .391 w/1.6 and a duration of 240/240. This is subjective, but you have to measure the cams anyway. I can confirm the .391 though. A real pig above 4k rpm.
