95 dakota xfer case problem
okay so i swapped out my leaky and what i assumed was, a worn original rear axle for a donor from the bone yard
there was a lot of play in the pinion so i assumed it was probally tearing up the ring gear with the pinion walking up and down the gear
okay so due to monitary issues it's been like that for a while and it showed up as a huge driveline slop
i have to work the clutch just right to stop it from sounding like Fonzie trying to say the word "wrong"
right, as i said i swapped the axle and i expected that my slop would go away but it only lessened to a degree, so i suspect that my transfer case is to blame
i suppose it can also be the tranny but i just can't see how that's possible
so finally to the question
if there was going to be slop in the xfer case..where would it be?
95 dakota, 5 speed nv3500, np231 xfer case, 8.25 axle 3.55 gears,
318 v8
thanx all in advance
318 v8
i had a problem with u-joints. pull the driveshaft off and rotate the front and rear joints for binding. if they are smooth then there is a bearing in the rear of the tranny that may be worn.
i can say for sure that my u joints aren't the problem
and i swapped the rear end yesterday, so i'm left with the xfer case or the tranny
i know for sure i have a bad input bearing in the tranny...loud in every gear except for 4th
and i do have slop in the driveshaft is i just grab it and rotate it...but no side movement
so again i have to come back to what might wear out in the transfer case to cause slop like that
or even the tranny
i know the xfer case isn't one solid shaft straight through, so is it feasable that i can get this kinda play in whatever couples the two parts of the mainshaft in the tcase?
or even the tranny
