thoguth i would ask here
Old Jun 25, 2011 | 05:47 PM
Deerkiller9991's Avatar
Deerkiller9991
Default thoguth i would ask here
those probe people dont seem to know anything compared to the people of dodge forums, but does this make any sense to anyone?
http://www.performanceprobe.com/foru...ad.php?t=42467
and would the push button be an (on off) button or a button thats only on when your holding it in?
thanks guys
Old Jun 25, 2011 | 06:16 PM
siggie30's Avatar
siggie30
What your wanting is a MOMENTARY SWITCH. Regardless, the benefit is if your ignition switch has failed and you have the materials available, you can readily make a circuit. You still have to unlock the column with the key which would negate the real value of push button starting comparable to modern systems. EDIT: I do not like the fact that the reference of taping wires is acceptable, especially with the starting circuit. I also, do not care for the ambiguous references to wiring locations, as using the momentary switch could be wired with only one wire to complete the circuit, of the relay, using the ground sensor.
Old Jun 25, 2011 | 11:49 PM
Deerkiller9991
no, i would do it the right way, no "taping snug" (the guy i bought my car from had the ground wires for the subs, fans, etc, just wrapped around bolts, no connectors, just bare wire) so after i fixed all the fire hazards im looking into other things lol. Also to I noticed, he said he used a cut up house extension cord, wth? but im not getting is what the white wire is for, shouldnt the switch have only 2 terminals? one to battery and the other to acc. ?
---ALWAYS USE WIRE CONNECTORS !AND! SHRINK TUBING/ ELECTRICAL TAPE. REWIRING A CAR DUE TO A FIRE IS ALOT HARDER AND MORE $$ THAN BUYING .97 CONNECTORS --- for people reading
Old Jun 26, 2011 | 01:39 AM
Crazy4x4RT's Avatar
Crazy4x4RT
+1 to that!
On my Dragstip TA I had installed a push button starter switch. I needed heavier wire than stock. Very easy install.
Autozone sells the starter push buttons, only closes when pushed and opens when released. I would post a link but Autozone site is down at the moment. I believe it was $10 or so. So here is a quick Google pic.
Edit: Here is the link to Autozone's part. http://www.autozone.com/autozone/acc...fier=6459_0_0_
Old Jun 26, 2011 | 12:12 PM
shadowthedakota's Avatar
shadowthedakota
those newer cars use a push button switch that only activates if the remote is within 30ft of the vehicle...my grandpa and i did this on the 49 chev pickup since the switches kept burning out...
Old Jun 27, 2011 | 12:56 AM
Deerkiller9991
alright, i have a nice bright red one i used for my air horn in my kota, might look into it, thanks guys
