Revamping 4X4 to engage by cable
Old Jul 3, 2011 | 11:11 PM
asosnoff's Avatar
asosnoff
Default Revamping 4X4 to engage by cable
92 has vacuum engagement problems, want to swap it to cable controlled. 2 questions, first how do you remove the vacuum canister, and will it leak without it. And once i am hooked up to cable, which do I engage first, 4 wheel stick on floor or cable to front axle, do I disengage in reverse order? Thanks in advance.
Old Jul 4, 2011 | 01:06 AM
dodgerules86's Avatar
dodgerules86
I'm not familiar with the CAD (vacuum) setup. But on the non-CAD, it's a solid rod, not a cable, and it leads to the transfer case only. On the non-CAD, like my 1996, there is no vacuum line or anything but the driveshaft going to the front axle.
Old Jul 5, 2011 | 08:10 AM
marcar1993's Avatar
marcar1993
Now is this engagement for a locking front diff?
Old Jul 5, 2011 | 12:08 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It is not to hard to take off the CAD. 4 bolts if I remember right. But yes it will leak out, and installing a cable will not be easy to do and keep it sealed. One option is to somehow permanently keep the CAD always engaged. Like stated before the 94-up are full time axles.
They do sell kits to engage the CAD by cable. But they don't have one for our axle. You can try to buy one for a Jeep or something similar to the actuator size and make it fit.
As for the order it wouldn't matter which is first.
Next option is to find a 94-96 axle and swap it in.
Or find a new or good used CAD actuator and replace yours. But most people say they can't find any new ones for some reason.
Old Jul 5, 2011 | 02:06 PM
9652dakota's Avatar
9652dakota
new ones are available at the dealer (i've orderd a few recently).
as for switching to cable. would be difficult and time consuming. i would just fix the cad or swap axles or lock it in place. you know the drill.
