ANTILOCK and BRAKE light
Old Jul 17, 2011 | 12:51 AM
bowhunter2k9's Avatar
bowhunter2k9
Default ANTILOCK and BRAKE light
my "ANTI" and "BRAKE" lights are on on my dash and I have no idea why... anybody had both of these on at once and how'd you fix it? no fuses are blown
Old Jul 17, 2011 | 02:13 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Here is a quick copy and paste of a diagnostic chart I posted in anther post.
Here these may help. If needed more info check out the FAQ for the service manual. It has everything.
I believe both lights can be lit up by a bad fuse/ bad power or ground to the ABS module.
Old Jul 17, 2011 | 03:21 AM
Rabid21's Avatar
Rabid21
Check the fuses around your dash.
I had this problem for over a week. If it is your fuse you also will have no brake lights.
Although I highly doubt you have the same cause for this issue for me I'll tell you what mine was.
A heavy duty Turn signal Flasher that was to much for my trucks electrical system. Blew through 4 fuses and 3 trips to the dealership before we figured it out.
Old Jul 17, 2011 | 02:44 PM
bowhunter2k9
thanks for the diagram i'll check that, and actually i do have another problem involving my right blinker... every time i hook to trailer lights the right blinker goes extremely fast/dim... or doesn't work at all
Old Jul 18, 2011 | 02:29 AM
payner6165's Avatar
payner6165
Hey, brother I had the same problem last year. Both brake and abs lights on the dash lit up but brake lights were operational. Took it a shop to check it on their computer and turned out to be a blown fues under the hood not the dash. Good Luck
Old Jul 19, 2011 | 07:33 PM
bowhunter2k9
hey man, do you know which fuse?... and also I didn't see almost anything but the brake fluid container in the diagram under my hood? 1992 dakota 4x4 5.2l
Old Jul 19, 2011 | 09:57 PM
RawDog's Avatar
RawDog
Or it could be like my truck and it doesn't even have an abs relay, or abs fuse in the PDC! Doh!
Old Jul 20, 2011 | 08:41 PM
bowhunter2k9
Yeah mine doesn't have one either...
Old Jul 22, 2011 | 03:26 PM
payner6165's Avatar
payner6165
Sorry man, the guy did not tell where the fuse was other than under the hood. I figured it was in the fuse/relay box near the batt. Good luck
Old Jul 22, 2011 | 04:48 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The FAQ has the fuse box and relay box diagrams.
