1994 Dakota....grrr
Old Aug 11, 2011 | 08:09 PM
garycm's Avatar
garycm
Default 1994 Dakota....grrr
Ok..here we go.....
I have 1994 Dakota. 3.9l 2wd automatic.
I had trouble with the fuel delivery, that is now working.
However, upon picking the truck up today, I have no brake lights, tail lights, head lights, front marker lights, horn, tach, cigarette lighter, dash lights or license plate lights.
I do have dome lights, hazard lights, turn signals, speedometer and the volt/ heat/ pressure gauges seem to be working. The fuel gauge has not worked since the fuel pump was replaced, everything worked light a charm before.
I have a good 20 amp fuse in fuse #8 in fusebox. I am lost here. I believe it should mostly run off the same couple of fuses, yet all seem fine.
Please..any help is appreciated.
Old Aug 11, 2011 | 08:12 PM
garycm's Avatar
garycm
is there any way to test the voltage going to the fuses? If so, how? and what would it be? I have a digital multimeter.
Old Aug 11, 2011 | 10:22 PM
rj67bu's Avatar
rj67bu
what was the problem with the fuel delivery? while testing the pump they could have been testing power from one source to another and grounded something out causing a blown fuse or relay
Old Aug 12, 2011 | 02:54 AM
Crazy4x4RT's Avatar
Crazy4x4RT
All fuses have a small open spot at the head of the fuse, put the positive lead on there and the negative on a good ground. Test both sides of the fuse. If nothing check a few fuses with known good circuits to test your ground. There are a few other fuses like the headlights ect. The FAQ has the fuse diagrams, under the dash and under the hood.
https://dodgeforum.com/forum/1st-gen...e-manuals.html
Old Aug 12, 2011 | 12:19 PM
qlty94's Avatar
qlty94
The tail lites might have been disconnected if they lifted the bed to work on the fuel pump
Old Aug 12, 2011 | 12:23 PM
garycm's Avatar
garycm
Well, I got it. The problem with the fuel delivery was caused by the 2 relays for fuel pump and ignition being grounded out. That was fixed, and when the black relay box by the battery was put back into place, the 50amp fuse in the relay box blew. I had checked my fuse box under dash, and some fuses like the #6, 7, 8 and others had no power at all. As soon as I replaced the fuse in the relay box, everything worked. Thanks for the ideas.
