92 Dakota 5.2 PCM?
Old Aug 22, 2011 | 08:36 PM
dobaroy's Avatar
dobaroy
Glad you got it fixed and thanks for the heads up on the battery terminal removal. I have to agree on the older non-computer vehicles.
Old Dec 7, 2025 | 08:03 PM
mullins80's Avatar
mullins80
Originally Posted by semccorm
I am working on a '92 Dakota 5.2 auto for a friend. No spark but cranks. I have checked the triple splice and it is fine. I get battery voltage to prong 30 on both the fuel pump anjd asd relays. If i push in on the Fuel Pump relay the pump runs (cap removed). However I get no codes from the PCM. In fact the check engine light never comes on even momentarily when the ignition is switched on. I checked the bulb and it is good. So where do I look next? Or could the PCM be bad as the check engine light never illuminates? All help is appreciated!
Pinout #32 bk/pk wire is the check engine light driver I do believe mine had a loose connection there.
Old Dec 7, 2025 | 09:44 PM
Uh, this is a 14 year old thread........ I would like to think he figured this one out some time ago. Please pay attention to dates.....
