Transfer Case Drain Plug Removal
Old Sep 13, 2011 | 12:27 PM
qlty94's Avatar
qlty94
Default Transfer Case Drain Plug Removal
On my 94 V6 4x4 there is little room due to the frame cross member to get a wrench on the bottom drain plug of the transfer case.I recall using a big crescent wrench but its too tight and that method now slips off.Any one out there have a tip
Old Sep 13, 2011 | 02:58 PM
dodgerules86's Avatar
dodgerules86
Ratchet, socket, extension.
Weird that you don't have space, my transfer case is about 6 inches from that crossmember.
Old Sep 14, 2011 | 12:24 PM
qlty94's Avatar
qlty94
1 1/2 inches on my 94 and its an xtra cab stl body.Maye be dodge makes a special wrench??Any how my repair tech told me he would have to remove the cross member to change the fluid so??
Old Sep 14, 2011 | 03:30 PM
Hahns5.2's Avatar
Hahns5.2
I also have a club cab, the torsion bar crossmember is several inches behind the t-case... The crossmember can't be removed, it's welded to the frame.
Old Sep 15, 2011 | 06:24 AM
melodytoinvent's Avatar
melodytoinvent
Yeah, same here and I had no problems at all getting to my drain plug...
Old Sep 16, 2011 | 12:10 PM
qlty94's Avatar
qlty94
The prior 3 posters don't show that they have a 1994 3.9 V6 Slt xtra cab so mine is a rare edition worth big $$.Seriously they do make changes year to year.
Old Sep 16, 2011 | 02:11 PM
MoparMan1991's Avatar
MoparMan1991
If you do drain your T case,m make sure you take out the fill plug first. If you remove the drain plug and let the fluid run out but cant get the fill plug out, then your pretty much SOL.
