Need help!
Old Sep 22, 2011 | 10:00 AM
DarkKnite2009's Avatar
DarkKnite2009
Unhappy Need help!
Ok so my dakota is stalling periodically but is getting worse now. I have replaced the coil and CPS (crank position sensor) and is still stalling. I am pretty sure its is in the ignition system because I have sprayed starter fluid in it and it will NOT start off it. I am running out of possibillities. has anyone had this happen to them before?
93' V6 3.9ltr
Old Sep 22, 2011 | 10:54 AM
Crazy4x4RT's Avatar
Crazy4x4RT
When it dies does it die like you turned off the key or does it stumble then die?
When it dies is it at idle or low throttle or do you have mid to high RPM's when it dies?
Does it start back up right away or you have to wait a long time?
The notorious splice is one possibility along with tons more.
Old Sep 22, 2011 | 03:44 PM
DarkKnite2009
it will stumble when driving. when it is idling it shuts off like the key is off. it never starts right back up.
Old Sep 22, 2011 | 04:12 PM
gezn2's Avatar
gezn2
Sounds like wiring gremlins to me, especially if it isn't throwing codes...
Notorious splice needs to be checked, similar issue on my '91 turned out to be a funky harness connector for the crank sensor. Get under the hood when it's idling and fiddle with things, move the wiring loom around and flex the connectors to see if you can make it repeat.
Damn gremlins had me seriously looking into a stand alone dist. and a carb for my Dak before I found the problem, making it guest-of-honor at a bonfire was also growing on me too ), so hang in there and we'll talk you through it as best we can...
Old Sep 23, 2011 | 10:25 PM
DarkKnite2009
like I said I think it has something to do with the ignition system but now I cant get it to quit I have drivin it 50 miles (since tuesday) and it still will not stall so I am completely stumped...... it stalled right after I put that sensor in but hasnt since...???????!
Old Sep 28, 2011 | 11:35 AM
DarkKnite2009
ok so it has stalled again same symptoms i put in a pick up coil and it didnt fix it. can you tell me where that ground issue is? I also put it on a spark tester and it wasnt getting spark.
