Speedometer jumping
Old Sep 30, 2011 | 09:51 PM
zevans08's Avatar
zevans08
Default Speedometer jumping
For about the past month the speedometer in my 1993, dodge dakota v6 automatic 2wd, has been jumping around while driving and you can hear a high pitch rattling noise coming from the gauge. It did this once before but quit after a few days but this time it has only gotten worse. It seems to be keeping accurate mileage. Any ideas?
Old Sep 30, 2011 | 10:37 PM
g. man's Avatar
g. man
I bet you need a new gauge. Or you have a bad connection. Best bet is to dig in and take a look. The local pull-a-part around here only charges $25 for the entire gauge cluster. Good luck
Old Oct 1, 2011 | 12:01 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Most likely it is the speedo cable. Just replace it, Napa has them for cheep. I replaced mine last year $20 or so, and very simple to do.
Old Oct 1, 2011 | 12:35 AM
g. man's Avatar
g. man
You think? Even with the gauge making that noise he described? Either way though, there's only 3 things involved that I'm aware of. Gauge, cable or sensor. I've only dealt with this on Honda's though.
Old Oct 1, 2011 | 01:40 PM
RockGuardedDak's Avatar
RockGuardedDak
could be the cable, or the gears in the gauge. My gf's 93's speedo acts up if its too hot outside and clicks and jumps. Makes a sound like the gears are skipping in the speedo. Could be another possibility
Old Oct 1, 2011 | 08:50 PM
zevans08's Avatar
zevans08
Thanks for the suggestions, ill take a look at the cable first and if that's not it ill look at the speedo its self.
