Brake sensor in prop valve
Old Oct 1, 2011 | 05:26 PM
hogback's Avatar
hogback
Default Brake sensor in prop valve
Do i need the prop valve senser it is leaking on my truck and i wonder if i can just put a plug in it or do i need to replace the whole prop valve
Old Oct 1, 2011 | 11:15 PM
dodgerules86's Avatar
dodgerules86
That sensor is needed.
It is the pressure differential switch, which is used to sense a pressure difference between the front and rear brakes (ie. fluid leak), and illuminates the "Brake" light on the instrument panel.
Old Oct 2, 2011 | 07:11 AM
hogback's Avatar
hogback
well where would be the best place to buy a new prop valve then
Old Oct 2, 2011 | 10:55 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Dealer might be your only bet or junkyard. I did a quick search on www.autozone.com and www.napaonline.com and didn't get anything.
Here is a copy and paste from the parts manual. I don't remember what truck you got this is for 94-96 2wd. I'm sure its the same all years and 4wd also, but not sure about 4wheel abs.
VALVE ASSEMBLY ***
5200 8304 1 Pressure Limiting w/Stud, w/Two ABS Limiting Valves
5200 8303 1 Combination or Metering, w/Bracket
5200 7818 1 SCREW, Pressure Limit Valve Motor
Old Oct 3, 2011 | 06:27 AM
hogback's Avatar
hogback
im going to try some junkyards its a 89 2wd
