91 dodge dakota v-6 starting problem
Old Oct 6, 2011 | 10:28 PM
Aparrish's Avatar
Aparrish
Default 91 dodge dakota v-6 starting problem
I have a 91 dodge dakota, 3.9 V6 (non magnum). Can't get it to start, went through timing, found compression on #1, timing is correct (1-6-5-4-3-2). fuel "drains" out of the injectors, for maybe 1 second upon turning the key to on, then when starting, no fuel appears to be coming out. Wondering if this might be a fuel pump not keeping pressure, or a computer component not functioning. Thoughts? Thanks. :0)
Old Oct 8, 2011 | 08:11 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Get a fuel pressure gauge and see what you get.
I will move this thread to the 1st Generation Dakota Sub-Forum.
Old Oct 9, 2011 | 04:49 PM
Aparrish's Avatar
Aparrish
thank you i'll try that, BTW your truck is SWEEEET
Old Oct 9, 2011 | 05:16 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Thanks!
