91 318 won't start, any ideas?
Old Oct 29, 2011 | 08:28 AM
bobby chabby's Avatar
bobby chabby
Default 91 318 won't start, any ideas?
Well, I was working late last night doing a flooring install, and when i went to start my truck (91 318 auto), it wouldn't start . It was pouring rain, so i got a ride home . Today, I'm heading back this afternoon to finish the flooring and to hopefully get my truck running .
It was running totally fine on the way to the job (it's run great ever since i've owned it) . Now, it turns, just wouldn't start . I'm going to check for spark on a plug wire first . If there's no spark, does anyone have any ideas what to check besides the capacitor or ignition coils ?
It seems like something electrical, for it to run fine, then not start back up, but i guess i'll find out this afternoon (hopefully the rain stops)
I know there are lots of possibilities, but does anyone have any ideas ?
thanks
Old Oct 29, 2011 | 09:04 AM
melodytoinvent's Avatar
melodytoinvent
Check the notorious splice under the relay/fuse box. The nasty weather coulda finally done it in. If you need more info on the splice, check the FAQ.
Old Oct 29, 2011 | 10:49 AM
bobby chabby
i'll check out the splice, thanks for the info .
This morning, i got a ride to my truck, and it's getting spark.
What would be the easiest way to check if i'm getting fuel.
I took off the air filter lid, and i didn't notice any fuel smell. I don't have much knowledge of fuel injection . Should i be smelling a strong fuel smell (like in a carberated motor that is cranked but won't start) ?
Old Oct 29, 2011 | 11:01 AM
g. man's Avatar
g. man
When you turn the key on, can you hear the pump prime?
Old Oct 29, 2011 | 06:35 PM
bobby chabby
Read the FAQ on the splice . Since I'm getting spark to the plugs, I guess the splice is alright (according tom the article) .
gman . What is the sound I should be listening for to see if the pump is priming?
Thanks
Old Oct 29, 2011 | 06:43 PM
bobby chabby
Just reread the FAQ on the splice . It said if I was getting spark, the asd relay was good. It also said there was a connection to fuel pump relays . If I'm getting spark, could the splice still be bad ?
I'm going to check out the truck tomorrow, today was cold & rainy.
Thanks for the help
Old Oct 29, 2011 | 07:46 PM
g. man's Avatar
g. man
You can hear it back by the gas tank. Shouldn't be any other noises but the pump back there. It's different from rig to rig, but it's a whine or hum. Not sure how to describe it.
