vibrations start at 65...
Old Nov 2, 2011 | 12:10 PM
4x4Dakota93's Avatar
4x4Dakota93
Default vibrations start at 65...
They start at 65-70, are in steering wheel , cab and pedal. The vibrations get worse as I get to higher speed and if I take my foot all the way off pedal when they get bad, its gets a lot worse...
Replaced everything on front end(except cv shafts), replaced slip yoke and driveshaft,u joints... Did a full alignment and wheel balance...
Shocks do need to be replaced but I don't think symptoms point towards them, one of my motor mounts driver side looks bad but vibration chart shows symptoms are differ, what else causes vibrations at this speed? Can bad fluids in transmission? Differentials? Transfer case cause this? Or maybe if fluid is alittle low?
Old Nov 2, 2011 | 12:20 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Did you balance your tires? That is one big possibility.
Old Nov 2, 2011 | 12:50 PM
4x4Dakota93
They said they did, I got a lifetime balance and alignment, imma go back to them again today
Old Nov 2, 2011 | 12:52 PM
4x4Dakota93
I was watching some videos online bout tire runout, might try when I get home but not sure what measurement is aloud
Old Nov 2, 2011 | 12:54 PM
marcar1993's Avatar
marcar1993
Either wheel balance or bent rims, even a little bit.
Old Nov 3, 2011 | 05:47 AM
4x4Dakota93
Wow my rear tires r cupped like hell
Old Nov 3, 2011 | 12:02 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Cupped tires are a sign of bad shocks, possibly part of your bad vibrations.
Old Nov 6, 2011 | 11:28 AM
crazyjerry's Avatar
crazyjerry
shot in the dark but maybe check the output bearing at the back of transfer case. see if theres alot of up/down slop where the drive line exits the tcase
