1996 Dodge Dakota 4 cyl will not start
I drove my truck with no problems until last week. I went to start it and it will turn over but will not start. I had the coil checked and it is good. I have no power to the coil or the distributor. I checked the ohms from the distributor to the crankcase sensor and there was good resistance there. I also checked the coolant sensor and even jumped the two prong wires in case the sensor was bad. I have no idea where the problem is and don't want to be buying parts when the parts I am replacing are good. I did, however, replace the cap and rotor since they were worn. The wires all checked good as well. Anyone have any ideas to what the problem is? Thanks!!!!
I live in Arizona and I have no corrosion problems anywhere in the engine wiring. I checked the crankshaft sensor and got resistance but no power from pins B and C. I applied battery power to the sensor and got 5 volts out of it but still would not start. I have continuity up from the crankshaft sensor to the distributor but no voltage. I replaced the distributor ignition coil and still nothing. I also checked the ASD and I am getting power there as well as explained in this forum. Any ideas?
