need a favor(4wd)
What tires do you have?
I have 31" tires and the distance from bottom of fender flare to ground is:
Front 33 3/4"
Rear 35 1/4"
The theoretical difference in ride height from a 235/75-15 (28 7/8") to a 31" tire is about 1" so if you have stock tires is should be 1" lower than the above noted numbers. My suspension is completely stock otherwise.
Front 33 3/4"
Rear 35 1/4"
