1994 dodge dakota 5.2L fuel pump
Old Nov 22, 2011 | 03:43 PM
darin89's Avatar
darin89
Default 1994 dodge dakota 5.2L fuel pump
Does anyone know if you can get just the electric pump and not have to buy the whole assembly i just priced it out here in canada and it costs anywhere from 260 dollars to 530 dollars. and if you can get just the electric pump and manufacturer part number would be great .
thanks in advance for any help
Old Nov 22, 2011 | 04:01 PM
bill55az's Avatar
bill55az
Seems to me that there should be an after market external fuel pump that gets mounted right next to the tank that would do the job....pull the assembly, reroute the hoses, dump the old pump while in there, and problem is solved...
Old Nov 22, 2011 | 04:20 PM
Bump's Avatar
Bump
Not that I could find. And no, its not just that simple to put on an external one because you have to find a good way to get rid of the old one and still run the gauges and low fuel light and such.
When buying a new one, keep in mind that the pump for 1994 and 1995 years are unique. I got a used one from a salvage yard from a 1996 and when I got mine (1995, 5.2L) out, the top of my old one said "1994 and 1995 models only" The wires would not connect properly. I needed one asap so I had to pay the full $200 from the local auto parts store, but if you can wait a few days, I'd order one from RockAuto.com.
Old Nov 27, 2011 | 11:48 PM
azvampyre's Avatar
azvampyre
Rockauto has the factory module repair kit for around $60.00.
PERFORMANCE ELECTRIC Part # P42K
Amazon has the Spectra Premium fuel module for $109.00 including shipping
Spectra Premium SP6163M
These are for the 94-95 w/318, and the Spectra module is for the 22 gallon tank.
