motor mounts for v8 dak
Old Dec 11, 2011 | 11:48 PM
  #21
rj67bu's Avatar
rj67bu
Another problem, the oil pan is to big. Anyone have any ideas
Old Dec 12, 2011 | 09:49 AM
  #22
bill55az's Avatar
bill55az
Look up the oil pan part numbers for an 89 Shelby dakota, and the 91 v8 2wd dakota, should be the same and will fit.
Old Dec 12, 2011 | 09:50 PM
  #23
rj67bu's Avatar
rj67bu
I found a shelby pan from transdapt $106 but i need to see this, just from the picture the sump is moved forward which is the problem the sump hits the crossmember. the 5.2 magnum pan would be perfect if it werent for the bigger rear bearing on magnum engines. Im going to the dealer this week to see if they have any info maybe even one in stock good luck on that but you never know. If someone else try's this be sure to use a magnum engine it's a much easier task as far as getting the motor in
Old Dec 12, 2011 | 11:32 PM
  #24
bill55az's Avatar
bill55az
have you tried AutoZone? Oreilleys? I got mine at autozone.
Old Dec 13, 2011 | 11:25 PM
  #25
rj67bu's Avatar
rj67bu
found one at autozone but it says front sump and there's no way a front sump will work. Does anyone know what differances there are in between the 88 and 1991 dakota? I'm just wondering if the frame had any changes
Old Dec 14, 2011 | 10:31 AM
  #26
bill55az's Avatar
bill55az
no frame changes.....
did you just look at AutoZone on line or go to the store? If they order in the wrong item, they have to make it good. The 89 Shelby Dakota oil pan is the one you want for sure, and the 91 2wd version should be the same.
Old Dec 20, 2011 | 06:12 PM
  #27
bill55az's Avatar
bill55az
back from being welded....these can be made from 4" channel, just whittle away what you don't want, a little bending, a little welding...
Old Dec 25, 2011 | 05:01 PM
  #28
rj67bu's Avatar
rj67bu
Just to let everyone know a guy came buy the other day and wanted to buy the Dakota, I sold it to him minus motor and trans. Thanks for all the help everybody specially you bill55az. I still have the 318 and A500 so I'll find a project for them this spring maybe
Old Dec 25, 2011 | 05:22 PM
  #29
bill55az's Avatar
bill55az
look at these, I was looking for something like this when I started, NOW I find them...
http://www.ebay.com/itm/318-340-360-...item35ae0dfd29
Old Dec 25, 2011 | 09:43 PM
  #30
rj67bu's Avatar
rj67bu
wouldnt you know it just when you dont need it any more there it is. Sometimes you just have to ask the right questions.
