Want to Tighten up Steering
Old Nov 29, 2011 | 05:36 AM
jaj1ie's Avatar
jaj1ie
Default Want to Tighten up Steering
My steering wheel is a bit loose and I want to give the truck a "tighter" feel to it.
ideas?
Old Nov 29, 2011 | 08:30 AM
festerw's Avatar
festerw
Loose pitman arm or idler would be the first two things I would check.
Old Nov 29, 2011 | 12:35 PM
kahanabob's Avatar
kahanabob
have someone turn the wheel back and forth while you look under the front end. look for play in the items in the above post also tie rod ends. there is an adjustment on the top of the steering box, a nut and screw.
Old Nov 29, 2011 | 10:40 PM
bill55az's Avatar
bill55az
Is it 2wd or 4 wd?
Old Nov 29, 2011 | 10:53 PM
jondakotaguy's Avatar
jondakotaguy
DO you know if the 97 has the same adjustment for the steering box?
Old Nov 30, 2011 | 04:51 PM
jaj1ie's Avatar
jaj1ie
Originally Posted by bill55az
Is it 2wd or 4 wd?
My 1990 is a 4wd
Old Dec 7, 2011 | 09:00 PM
logancounterman's Avatar
logancounterman
This kits pretty cheap for what you get and will give you that "tighter" feel.
just click the link.
\hope it helps
http://www.ebay.com/itm/SUSPENSION-S...item20b622f506
Old Dec 8, 2011 | 02:10 PM
jaj1ie's Avatar
jaj1ie
definitely looks like everything I would need. My shop quoted $50 each for just the lower ball joints. What will the quality be like for that kit? Clearly not original Dodge, probably all I need though?
Old Dec 8, 2011 | 06:36 PM
logancounterman
I would believe it would be a good kit. only thing would be that you gotta change them yourshelf.
good luck,logan.
