Broke CV Joint help ASAP
Old Dec 13, 2011 | 09:52 PM
DakDaddy's Avatar
DakDaddy
Exclamation Broke CV Joint help ASAP
I broke the outer part of my front driver side cv joint, question is, can I still drive it? I need the truck for atleast one more day. ASAP ANYONE.Broke CV Joint help ASAP-brokecv.jpg
Old Dec 13, 2011 | 10:17 PM
Sauxon's Avatar
Sauxon
If it is only ripped open, then go for it but you will have a mess to clean up.
If it has somehow managed to actually fall apart, I definitely would not drive it as it would be flopping around hitting everything.
Old Dec 14, 2011 | 01:15 AM
festerw's Avatar
festerw
You can pull the outer joint apart and use the stub to hold the hub together.
