my 1996 dodge dakota wont go in reverse
Old Dec 15, 2011 | 01:55 PM
DaKOTA MAN000's Avatar
DaKOTA MAN000
Default my 1996 dodge dakota wont go in reverse
i have a 1996 dodge dakota automatic that will not go in reverse. it is as if it were in neutral. but it drives just fine any suggestions
Old Dec 15, 2011 | 02:48 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Possibly bad or low fluid, or miss adjusted bands. But most likely you need a complete rebuild.
Old Dec 15, 2011 | 03:00 PM
kahanabob's Avatar
kahanabob
take a look at the shifting linkage down under on the drivers side. there is a rod that goes from the motor side to the body side and is held in place with nylon keepers. they go bad, one of mine fell out and the linkage seperated and did not shift at all. might be an issue there??????????
Old Dec 15, 2011 | 05:00 PM
RockGuardedDak's Avatar
RockGuardedDak
the truck drives fine, so im assuming that you got forward drive DaKOTA MAN000? if so, then the shifting linkage will not be the issue kahanabob
Old Dec 15, 2011 | 07:00 PM
shadowthedakota's Avatar
shadowthedakota
would also suggest checking the filter. when my old one clogged up i slowly lost each gear till i only had 1st and 2nd left...
Old Dec 15, 2011 | 09:28 PM
kahanabob's Avatar
kahanabob
can't hurt to take a peek..........
Old Dec 16, 2011 | 05:23 PM
RockGuardedDak
OD was first to go? If so, did you get a code 45 with that? Code 45 is the OD solenoid
