Got a twitch.
Old Dec 28, 2011 | 10:53 PM
just jeff's Avatar
just jeff
Default Got a twitch.
Anybody ever have their fuel gauge go all "twitchy"?
Cant afford to fill it up, cant afford to run it empty!
Old Dec 29, 2011 | 02:10 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Sounds like a bad wiring connection or a bad float sending unit. The FAQ has a write up on swapping in a new float.
Old Dec 29, 2011 | 02:22 AM
RockGuardedDak's Avatar
RockGuardedDak
Would a bad float sending unit cause the gas gauge to only act up during certain spots in the tank? For example, from 3/4's of a tank to 1/2 a tank, my gauge will go all over the map, but above 3/4's, or under 1/2, the gauge works fine..
Old Dec 29, 2011 | 10:38 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes if there is a bad spot on the resister board, which is common since it can rub off over time.
