Start issue
Old Dec 30, 2011 | 06:48 PM
jvt's Avatar
jvt
Default Start issue
Intermittently, when I try to start the truck ('93 3.9 6cyl), the key turns and it's just a click. Sometime I turn it back, try again and it starts right up. Other times it turn click, turn click, turn start, etc. Any ideas?
Thanks!
Old Dec 30, 2011 | 07:22 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Possibly a bad starter or a bad ignition switch.
Old Dec 31, 2011 | 12:53 AM
crazyjerry's Avatar
crazyjerry
be sure you got a good clean tight connection between battery posts and wire ends. seen this same type of problem when connections get corroded at the battery terminals.
Old Dec 31, 2011 | 03:36 PM
nemesis158's Avatar
nemesis158
most likely your starter going out
Old Dec 31, 2011 | 05:06 PM
g. man's Avatar
g. man
x3 on the starter, but checking connections first. If it is your starter don't waste your money at the parts store. Find a local shop to rebuild it for you. Save lots of money that way. There is a local shop near me that specializes in starter and alternator rebuilds, I don't know if they are common or not.
