How to: Hanger Flip, Dodge Dakota
Old Jan 14, 2013 | 09:44 PM
jimmy_d's Avatar
jimmy_d
Does this mess with the driveline angle?
Old Jan 20, 2013 | 03:29 PM
Meezyy Jayy's Avatar
Meezyy Jayy
Its hard to say, if you drop the rear without doing the front than yes, but if you drop the front, your angle should be fine. I rode around for about 6 months with the rear dropped and the front at stock height, and it wore out the rear u-joint, but when i lowered the front two inches, it evened out perfect, no more vibrations.
Old Aug 11, 2013 | 07:03 PM
Dak Hak's Avatar
Dak Hak
I just bought back my 1994 Dak after 15 years of being without it. Anyway, I am going to give it a nice street stance using this hanger flip for the rear. I have a question about the 5x5 rubber sheet in the instructions. Is this used to protect the underside of the bed from hitting the hanger / springs? If so, has anyone damaged their bed with this flip?
Old Aug 13, 2013 | 04:13 PM
EvilSRT's Avatar
EvilSRT
I plan on doing this to my '95 eventually. Thanks for the write up.
Old Aug 14, 2013 | 12:36 PM
Dak Hak's Avatar
Dak Hak
If you get to this before me, please let me know how it goes. I am curious how close the hanger is to the underside of the bed and if this poses any problems. If anyone knows the answer to this, please chime in!
Old May 2, 2019 | 11:01 PM
whiskeysawdust's Avatar
whiskeysawdust
Originally Posted by Meezyy Jayy
Is this after the front was done too or just the rear?
Old May 10, 2019 | 04:46 PM
volaredon's Avatar
volaredon
My only question is WHY????? Lowered trucks are useless.
Old May 10, 2019 | 08:03 PM
onemore94dak's Avatar
onemore94dak
Old May 11, 2019 | 02:33 PM
Noonbailey501's Avatar
Noonbailey501
Looked under my truck and mine are pretty rusty I was wondering if I couldn’t use 2nd gen hangers to replace my old ones because the hangers as far as I can look are N/a
Old May 11, 2019 | 02:45 PM
Probably have to measure what you have, and then have someone measure theirs for you. 3/4 and 1 ton trucks have three inch wide springs, so, likely will HAVE to come from a half-ton.
