Fuel rail ?
Old Jan 4, 2012 | 07:27 PM
1stG92's Avatar
1stG92
Default Fuel rail ?
I may have solved the issue with my truck.Gotta get a fuel rail tomorrow and see if this is it.My ? is,there is something on the fuel rail with a vacuum line connected to it,it is part of the rail so I cant just change it.Anyone know what this is?
Old Jan 4, 2012 | 07:46 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm assuming your referring to the fuel pressure regulator, it has a vacuum hose hooked up to it. With idle vacuum it limits the regulator to help with MPG with little to no vacuum when the engine is at higher RPMs the pressure goes up.
If you think the regulator is faulty double check it with a fuel pressure gauge and check it with and without vacuum.
Old Jan 4, 2012 | 08:13 PM
1stG92's Avatar
1stG92
Ty.I assumed the regulator was on the fuel pump...then again I may have been looking at the wrong engine in my search....Is there one on the pump also??? Just out of curiosity.
Old Jan 4, 2012 | 10:50 PM
Crazy4x4RT's Avatar
Crazy4x4RT
92-93 the regulator is on the fuel rail and on the frame rail a fuel filter.
94-96 both filer and regulator is in the tank.
For you no there is not a 2nd regulator which would be pointless.
Old Jan 7, 2012 | 08:15 AM
1stG92's Avatar
1stG92
Thanx Crazy..After testing the regulator we found that was my issue.My problem was thinking it was on the fuel pump,lol.Got a fuel rail yesterday and will be changing it out over the weekend.I did do a pressure test but came back good.When I take the vacuum line off the regulator it runs better,doesn't cure it but does run better.
