1993 Manual Transmission Problem
Old Jan 17, 2012 | 04:17 PM
SithHawk's Avatar
SithHawk
Default 1993 Manual Transmission Problem
Hello, My 93 Dakota 2wd will not shift into 3rd gear, it acts like it does not exist. I also cannot get it into 4th gear. 4th gear just sounds like it is grinding. Somebody told me that the clutch needed to be replaced but I am not sold. Any other ideas would be very helpful. Thanks.
Old Jan 17, 2012 | 07:48 PM
bjr1a's Avatar
bjr1a
If reverse, 1st , 2nd and 5th are working, then the problem has to be internal......
Old Jan 17, 2012 | 10:08 PM
crazyjerry's Avatar
crazyjerry
something inside would be my guess if other gears are working
Old Jan 18, 2012 | 09:27 PM
GTXpress's Avatar
GTXpress
Your 4th gear grind, is it not going in and grinding? Or going into 4th and then making noise?
If it is the first one, I would look into synchronizers. If the latter, somehow a gear possibly grenaded. Either way I would drain the fluid and see what you have going on. Then asses your problem based on whats going on and what you see.
Old Jan 19, 2012 | 01:37 AM
marcar1993's Avatar
marcar1993
Perhaps completely unrelated, but my friend has a mustang with a t-45 5 speed, he could not get into 3rd or 4th and it turned out he broke the shift fork internally.
