Cheap Engine Upgrades
okay guys i have a 91 dak v6 auto and i was wondering if there are any cheap mods i can do to make this thing quicker and maybe some more power in the high end. i would love to pass people on the highway at 60 without having to punch it ad waste gas. thanks
I am not sure but does Autozone sell bolt on cylinders? Cause you need two, a right and a left!
No j/k. Get on Jegs, get a nice street cam that will put your power band into some higher RPMs if thats where you want the power. Open her up and let her breathe!
its hard to gain performance and keep fuel mileage
Cam if there is one for the LA. Headers if there is one for the LA. Larger exhaust pipes. Larger fuel injectors.
As for best bang for the buck is going to be a complete rebuild with lots of machining work like decking the heads and block, oversize pistons. Port and polish the heads and intake if anything at least gasket match the intake and heads. Boar out the throttle body.
You could also lower the rear end gears.
Turbocharge it or Nitrous.
so basically what your saying is get some better fuel injectors, better heads (im pretty sure 92-93 magnum manifolds will fit), could i get a v8 TB and probably a home brew CAI. then swap out the rear end with a 4.10?
Yes you could even do Magnum heads but with the LA block it is not worth it.
As for the V8 Throttle body, I don't know what the differences between the V6 TBI and V8 TBI is. Maybe it will work.
Sure do a good CAI.
4.10 is great for launches bad for freeway with street tires.
If your really set on not dropping in a V8 and keeping a V6 then I would suggest to drop in a Magnum 3.9 V6 compete. Even if you do all upgrades said in this post your still dealing with a stock TBI PCM that was doesn't have the best MPG + performance. The Magnum PCM has enough adaptability to compensate for upgrades and get the most out of them.
From what has been said the Magnum block will drop right in. If you get a complete engine/wiring the swap will be simple. All the engine control wiring is under the hood.
okay i'll look into it, it kinda sounds like i should just get car and try to make that fast lol ans keep my dak looking good but slow.
Trending Topics
No it just sounds like you need to get away from the V6 and get a V8.
Engine, probably trans, driveshaft. Could look and make sure you are running a good gear set, I really think you are prolly around a 3.92. Let us know what you are running.
But if you want to go fast I would say get a car as well. Or get a car for fuel mileage and rod out the truck! Either way.
Low and slow has its place too!
