My brother has a 95 Dakota Sport. He changed the light switch and the multi function switch and still has no headlights. All others work. No clue what to tell him any help would be great. Thanks in advance.
I will move this to the 1st Generation Dakota sub-section. In that section the FAQ has wiring diagrams in the service manual. It sure sounds like a wiring problem.
do you have high beams if you hold the switch back that you use to switch from low beam to high beam? mine did that and it was a loose connection at the on/off switch.
