'91 V8 5.2Liter ignition troubles
Old Aug 8, 2005 | 01:34 AM
sar's Avatar
sar
Default '91 V8 5.2Liter ignition troubles
I went out to start my 91 Dakota (V8, 5.2L) today but there's no spark and it won't start. It ran fine yesterday evening. The TBIs seem to be working(the bore is wet with fuel) and the engine is cranking but there is no HT output from the ignition coil. The coil has continuity, but I don't have my DVM nearby to check the resistance.
Computer codes as follows:
12 - Battery or computer recently disconnected
33 - Air conditioning clutch relay circuit open or shorted (may be in the wide-open-throttle cutoff circuit)
42 -
42 Automatic shutdown relay circuit open or shorted
42 Fuel pump relay control circuit
42 Fuel level unit - no change over miles
55 - End of codes
All the fuses are good and the relays seem to be working fine. When I bought the vehicle I vaguely remember a friend of mine fixed a part of the wiring harness under the under-hood fuse box. The connection was very corroded. I cut the tape off the harness but the wiring looks pretty good in there. Any particular wire (color?) I should look at, or am I chasing the wrong thing?
