Tips On Wiring?
Old Feb 14, 2012 | 02:23 PM
Siwon's Avatar
Siwon
Default Tips On Wiring?
Can anyone give me some tips on how to wire something from the rear to the battery, and to the dash for a switch?
My tailgate has a light in it and the wires are following a piece of metal to the front, do I use this?
For the switch, do I push it through from the dash or from behind the engine to get it in the cab?
I don't have a big car lift, and some places want like a hundred bucks to do it.
Old Feb 14, 2012 | 02:42 PM
marcar1993's Avatar
marcar1993
Ok, my personal opinion is get a relay. Wire from the switch to one side of the relay then the battery to the other side.
Then the battery side to the back of the truck.
Here's a quickie diagram that should make it clear as mud.
Get a relay, switch, and wire rated for more amperage than you will need. Also, you may want to put an inline fuse in both sides of this.
Old Feb 14, 2012 | 02:58 PM
Siwon's Avatar
Siwon
I think you need to read my post again!
I'm wondering HOW to run the wires.
Clear as mud? You didn't even put the pin numbers lol
this is the schematic I already made
Old Feb 14, 2012 | 04:36 PM
festerw's Avatar
festerw
My 92 has a wire bundle that runs along the drivers side frame rail I followed that and zip tied it in place.
To get through the firewall punch a small hole though an existing grommet and seal it up with some RTV.
Old Feb 14, 2012 | 10:29 PM
GreenDak22's Avatar
GreenDak22
Yeah just run them on the frame rail and make sure they're secured to it, easiest being zip ties
