t case problems
i have a 95 dakots wit a 3.9v6 and the t case is stuck in 4 high and 4x 4 light is out and the shifter is in 2 high is the t case shot? i really dont know a lot about dodges and if it is shot is there any other t case that will work
The link that was posted in the other thread you replied on has a listing. http://www.drivetrain.com/parts_cata...rts/dodge.html
It sure sounds like the shifter needs adjusting. Look below at the adjusting bolt.
i did that and the bolt was still there and the t case is still stuck in 4 hi so the t case is shot?
Trending Topics
you have to do some investigating on your own. the linkage can be put on upside down, causes it to stick in 4hi. maybe someone got the lickage upside down. unhook the linkage at the tcase and verify the shifter moves freely. you can also manually shift the tcase after you unhook the linkage from it. open end wrench fits perfect on it. just a matter of process of elimination to find the problem. could be something internal but check everything else first
The hose is a vent hose not a vacuum hose. Pre 93 they did have vacuum hoses coming off of the transfercase up to the front diff for the CAD. But yours being a 95 and assuming someone didn't swap in an earlier year front axle or transfercase in it.
If you loosen the bolt you should be able to move the shifter all the way up and down. Then adjust it as you need.
The service manual in the FAQ describes it in more detail.
