Bolt ons?
Old Mar 15, 2012 | 04:02 PM
Kota94's Avatar
Kota94
New Member
Smile Bolt ons?
Aybody know of any direct bolt ons out there off of other vehicles for a couple simple mods on my 94 318 dakota? Thanks!
Old Mar 15, 2012 | 06:26 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 1st Generation Dakota Sub-Forum.
As for your question, basically no nothing is a simple bolt on. The best thing is to open up the intake manifold ports and heads and exhaust manifolds as well as the throttle body, which to do that you will need to grind down the interior ports with a dremmel tool and a coarse bit.
Actually the best bolt on is a 5.9 Magnum engine, it is a simple bolt on. Also drop in the 5.9 PCM. Other than that all aftermarket performance parts.
Old Mar 15, 2012 | 09:34 PM
Kota94's Avatar
Kota94
New Member
whats that out of, full size dodge? Am i going to need any wiring harness conversions? or make any custom fits? and will it bolt up to my stock tranny?
Old Mar 15, 2012 | 10:23 PM
Crazy4x4RT's Avatar
Crazy4x4RT
As for the PCM Ram or Van with the 5.9 Magnum V8 93-95. You can drop in the motor from 93-03 but your going to need to use your electronics.
Old Mar 15, 2012 | 10:54 PM
Kota94's Avatar
Kota94
New Member
So if i go with the 5.9 from a 93-03 van/ram ill have to convert or i will be able to use all my wiring for the ew engine drop? sorry if this seems obvious but i just got a little confused
Old Mar 15, 2012 | 11:00 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Keep your 5.2 intake and everything above. Use the 5.9 engine block and heads complete harmonic balancer and flywheel and all.
Old Mar 15, 2012 | 11:08 PM
Kota94's Avatar
Kota94
New Member
tranny bolt up?
Old Mar 16, 2012 | 12:58 AM
marcar1993's Avatar
marcar1993
yes it will.
