Sensors
Old Mar 17, 2012 | 07:44 AM
dobaroy's Avatar
dobaroy
Default Sensors
Removed the trans from the '93 V6 (parts truck) and there are a couple of sensors that sit at the back of the motor, just kinda near the top of the bellhousing and just wondered what they would be and how to get them out of there. Also a friend of ours wants the exhaust manifold but he has a second generation, wondering if the V6 manifolds would interchange? Thanks, Roy
Old Mar 17, 2012 | 08:36 AM
Crazy4x4RT's Avatar
Crazy4x4RT
There is only 1 sensor back there. It is the crank shaft position sensor. It has 2 simple bolts on the out side.
As for the exhaust manifold it will fit on the engine just fine, but the placement of the exhaust pipe might be slightly off. Just pull them and let him decide if he thinks it will work. since it is 92 the exhaust manifold has a larger interior diameter vs other years.
Old Mar 17, 2012 | 12:16 PM
dobaroy's Avatar
dobaroy
Thanks Crazy, not sure what else I was seeing back there, lol, will have another look.
