Old Aug 6, 2015, 11:56 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Aftermarket Stereo/Head Unit Help, What works, pics?
Old Mar 25, 2012 | 05:55 PM
  #21
Motorcharge's Avatar
Motorcharge
Originally Posted by dakota92le
That white dash looks amazing, I was actually considering painting mine black, I'm assuming you prepped it, sanded the fake wood grain off?
Just removed it, gave it a good cleaning, and sprayed it with Krylon fusion. Works awesome on plastic. All the white was black previously. Working on getting a dash cover and painting all the interior trim black.
I like the ceiling mount idea, running the cables down turns me off though, I'm pretty inexperienced and lazy, I understand it needs a base to mount on, why a ping pong paddle?
You have to pull the 2 side panels off above the doors to remove the headliner anyway, you can just run the wires down the drivers side panel down under the dash then through the firewall. The headliner is super easy to remove on the Dakotas.
As for the ping pong paddle, they're durable but thin and cheap. Cheaper than buying a whole sheet of plywood just for a small piece to cut out.
Old Mar 26, 2012 | 04:03 PM
  #22
SXX360's Avatar
SXX360
First off, i doubt that the 4x60W is the RMS power of the headunit. Most headunits put out about 4x20W RMS to each speaker. What headunit are you looking at getting exactly? Just an FYI the more detail you give the more detailed responses you will recieve.
You can put 6x9's in the rear. However you may have to mount them to the metal instead of using the stock location on the plastic. Then again you can put any size speaker anywhere it just depends on how much you want to go through to put it there.
Old Feb 16, 2015 | 07:09 AM
  #23
nxrunner's Avatar
nxrunner
New Member
anyone have a mounting depth for the door speakers?
