Help! randomly dies out.
Old Apr 22, 2012 | 12:35 AM
Dodge4lyfe's Avatar
Dodge4lyfe
well it wasn't the coil, I still have no spark. also, the computer has been replaced and I've tried moving the connector. its completely dead now, its not intermittent anymore at least...
Old Apr 23, 2012 | 09:40 AM
Dodge4lyfe's Avatar
Dodge4lyfe
well, its not the coil... what now?
Old Apr 23, 2012 | 09:48 AM
tml1138's Avatar
tml1138
New Member
If there is no spark, something has to be an issue that delivers it. Or something else is causing damage to components that give you spark. (Bad electrical short, causing your new coil to be ruined the moment you try it out, for example.) You said new wires... Maybe a bad ground?
Or the computer connector. If it was working intermittently, and you moved it to put in a new computer and now it's completely dead...seems that connector could be suspect to me.
Old Apr 24, 2012 | 09:34 AM
Dodge4lyfe's Avatar
Dodge4lyfe
we'll see, the guys where I work are looking at it today...
Old May 5, 2012 | 09:09 PM
Dodge4lyfe's Avatar
Dodge4lyfe
problems fixed, it was spliced wires by the pdc that were broke. it also fixed my overcharging issue.
Old May 16, 2012 | 10:18 AM
tml1138's Avatar
tml1138
New Member
Glad you found it! Sorry but I'm not familiar with the acronym...what is the PDC?
Old May 16, 2012 | 11:00 AM
Crazy4x4RT's Avatar
Crazy4x4RT
PDC Power Distribution Center, its the relay and fuse box under the hood.
