Ground Problem!
Old Apr 28, 2012 | 01:32 AM
pinkfloydeffect's Avatar
pinkfloydeffect
Originally Posted by buick
I'd highly recommend soldering them as well. The vibrations/movement from the motor and travel can really loosen things up.
Also, did you replace your big three? 1) alternator positive to battery positive, 2) battery negative to chassis, and 3) engine ground to chassis
good write up on this upgrade
The absolute ground of your electrical system is not your neg battery terminal, but the case of the alternator. Assuming the alternator is properly bolted to the engine, your block to chassis ground is your most important ground. It's usually one of those pansy braided flat cables from somewhere lower down on the block to the chassis.
Not yet but will be soon enough, I will solder my new 1/0-G terminal. The only one I have touched so far is the negative to fender/body ground since that is where I needed the girth (grounding my amp(s) to the cab/body). The red wire is 4-AWG but today my 1/0-AWG came in (same exact cable I use on my positive for my stereo) along with a GOOD terminal for the negative to match my positive terminal (and gold plated fender terminal):
Old May 10, 2012 | 10:37 PM
pinkfloydeffect
I finally did the positive side and the problem came back but not as bad. It only lasted a day or two when I did the negative, maybe it has something to do with when I disconnect the battery? Computer reset or something?
