Help, fan and heat stopped blowing
Old May 1, 2012 | 11:46 AM
Siwon's Avatar
Siwon
Default Help, fan and heat stopped blowing
95 Dakota slt
Going down the road with AC high and the blue button on, the fan kept going in and out about 3 or 4 times and then it completely stopped blowing!
I can feel the heat when its on but it doesn't blow.
Fan clutch ? Or fan? How go I go around fixing it?
Old May 1, 2012 | 12:11 PM
buick's Avatar
buick
Originally Posted by Siwon
95 Dakota slt
From the FAQ:
My heater blower doesn't work on all the settings- Chances are that the blower resistor block is faulty. The resistor block is located on the passenger side firewall. It's very easy to change out.
The resistor block is the most likely culprit. It's about as easy as a repair as you can get. $6-8 part, unclip one wire socket, undo 2 screws, redo 2 screws, reclip socket, done!
Old May 1, 2012 | 12:17 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Which fan went out? The engine fan? Or the blower motor for the heater and AC? If it is the blower motor it doesn't have a fan clutch, that is what is where I'm unsure which fan your talking about.
If it is just the blower motor it most likely is the resister pack that is bad. The FAQ has the write up.
Old May 1, 2012 | 02:44 PM
Siwon's Avatar
Siwon
The AC/heat fan. Thanks for the replies, here you go!
The wire isn't even connecting to the metal because it burnt right off or something.
Old May 1, 2012 | 03:53 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Nasty!
Old May 1, 2012 | 03:56 PM
Siwon's Avatar
Siwon
haha I bought a new one from autozone and put it in right there and it works now
