A/C blows when rpms are lower
Old May 19, 2012 | 12:48 PM
Olblue's Avatar
Olblue
Default A/C blows when rpms are lower
1995 dodge Dakota 4x4 manual
So when driving and a/c is on it started blowing threw the defrost vents above dash while driving then let off the gas a little then it blows through the front vents? It just started doing this? A/C is cold and blows hard?
Old May 19, 2012 | 02:03 PM
Crazy4x4RT's Avatar
Crazy4x4RT
There is a vacuum check valve that holds vacuum for the vent doors that probably needs replacing.
Old May 20, 2012 | 06:51 PM
Olblue's Avatar
Olblue
Ok where is that check valve located? Thanks!
Old May 21, 2012 | 12:20 AM
Crazy4x4RT's Avatar
Crazy4x4RT
On the vacuum lines. Check the sticker under the hood.
