Still can't get transfer case removed
Old Jun 10, 2012 | 05:39 PM
rbhb2's Avatar
rbhb2
Question Still can't get transfer case removed
Help!!! I removed the torsion bar and followed the advice of nextlevel in this thread: https://dodgeforum.com/forum/1st-gen...e-removal.html and still can't get the transfer case out. I need about 3/8" to 1/2" more before the studs will allow me to rotate the case. Any other suggestions? I am considering cutting the studs but then how will I get the replacement transfer case back in? Is it possible to push the transmission/engine forward a bit? How would I do that? It's a 1995 with automatic transmission. The truck is still strong so I don't want to give up on it but this is getting ridiculous! Thanks, rbhb2
Old Jun 10, 2012 | 06:02 PM
Crazy4x4RT's Avatar
Crazy4x4RT
My best guess is the weight of the transmission and transfercase is fighting you. Try to jack up the transmission just to stabilize it, then maybe jack up the transfercase just slightly to relive the weight of the transfer case off of the transmission.
Old Jun 10, 2012 | 07:08 PM
rbhb2's Avatar
rbhb2
Thanks for the quick reply. The transmission was supported. I tried raising and lowering the transmission up as far as it would go and every position in between and could manhandle the transfer case. No luck.
Old Jun 10, 2012 | 10:15 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Post up some pictures.
Old Jun 11, 2012 | 10:58 PM
Dodge4lyfe's Avatar
Dodge4lyfe
mine was a bugger too. loosen the transmission mount and Jack up the rear of it as much as you can, then push the lower side (left side) of the transfer case forward as far as you can while rotating it counterclockwise and pushing it away from the studs. its quite a task, but doable...
Old Jun 24, 2012 | 10:51 PM
rbhb2's Avatar
rbhb2
Default Update and another question
Well, I was able to finally get it out. I ended up using a come-along by wrapping the cable around the transmission mount and leading it forward under the engine to the hitch on another truck. The 3/8" made the difference but it was still a royal PITA.
After removing the transfer case I noticed that the input gear shaft on the one I took out is 3/4" longer than the replacement. Both are 231D's but the build date on the one I took out was 9/24/94 and the salvage unit's build date is 1/16/96. Is that gonna cause a problem? Thanks, RBHB2
Here is a pic:
Attached Thumbnails Still can't get transfer case removed-img_3623_1_1_1.jpg
Old Jun 24, 2012 | 11:37 PM
Crazy4x4RT's Avatar
Crazy4x4RT
If I remember right the transfercase that came on the automatics use a longer input shaft vs the ones that came with manuals. The input shafts are interchangeable.
Old Jul 10, 2012 | 01:38 AM
rbhb2's Avatar
rbhb2
Unhappy Got it in but still have question on seals
Thanks for your advice. Well, I got it in. What a difference the short input shaft made... 1000times easier. But here's the problem: I have had a serious drip coming from the transmission to transfer case joint. I know it was coming from the transfer case because I had not refilled the transmission. I had filled the transfer case to the bottom of the top fill hole while the truck was on the ramps and the torsion bar was unassembled. After I reinstalled the torsion bar ATF started dripping (as the truck raised). I had only put in about a quart and a half and it seems about a quart dripped out. It stopped dripping then started again after I took the truck off the ramps. It stopped again until I ran it around the block and a few more ounces dripped out. It starts dripping every time I test run the truck but stops after a while. Unless this is normal I must have bunged up the new seal. Anybody have an idea if it is normal to drip like that? Can anybody tell me the proper procedure for installing seals? I don't look forward to pulling the T-case again. Do you agree that I must have screwed up the seal?
